Thread: Inaccurate water temp reading
    Default Re: Inaccurate water temp reading
    Quote Originally Posted by waste View Post
    I assume that the air temp sensor is also hooked up and giving you an accurate air temp reading - <quick and dirty> - switch the wiring to the two sensors and check what they're saying. You can also go over to the unit and see what it's saying 'in the box', just to be sure it's not a problem with the remote unit.
    {edit}You can also remove the sensor and check for deposits, cracks etc. - Easy enough with a flat-head screwdriver, but even easier with a 5/16" nut driver (even easier with a 5/16" bit in a cordless drill - but dial down the clutch when retightening it ){edit}
    Thanks for the response. Good idea about checking the Aquarite display. The Aquarite unit outside is reading the correct water temp,(matches the thermometer in the pool within 1 degree) which indicates to me the sensor is ok. Is there some sort of calibration procedure between the two units?
    mas985's Avatar
    Pleasanton, CA
    Sorry about the first question but I had to ask.
    The main temperature circuitry is at the main unit outside. The remote display is just that, a display, and does not measure temperature itself. It should have identical readouts to the main unit. It sounds as though the remote unit may have a problem. Try disconnecting it or turning off and then on to see if it can reset itself. You may need to power cycle both units.
    Mark
  1. Aqua Comfort S125 Heat Pump Not reading Water Temp Correctly
    By ghostcat in forum Pool Equipment & Operations
    Last Post: 07-20-2012, 11:12 PM
  2. Water temp to Cl correlation
    By scuba in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-05-2011, 07:32 PM
  3. Wrong temp sensor reading
    By mkelley in forum Pool Equipment & Operations
    Last Post: 10-12-2007, 12:31 AM
  4. Water temp short
    By tropic in forum Pool Equipment & Operations
    Last Post: 08-24-2007, 03:38 AM
  5. Water Temp
    By jcpbnp in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-05-2006, 07:14 PM
