Results 1 to 10 of 18
Thread: Pool light for existing IG pool
Threaded View
  1. #2
    Smile Re: Pool light for existing IG pool
    Steve, as this is my first time 'threading' with you, let me say (a belated) - welcome to the forum! There is a retro install light (AquaLumin II). While we usually install them when the liner is being replaced, it can be done without draining the pool and replacing the liner (it's a little more tricky, but certainly possible). The unit is a 'nicheless light' and all you need to do is drain ~2' of water, pull the liner away from the installation area, drill a 3" hole in the pannel and install a modified return fitting. (Of course you need to prevent debris from getting behind the liner and dig under the deck to install the conduit, but it's really not that hard to do). I'll see if I can (for once) successfully Google up a link for them.
    If you've any questions about what I've said, just ask! - Waste
    http://www.pentairpool.com/misc/owne...Lumin%20II.pdf
    (that only took 5 tries! )
