One other thing to try is to fire up the pump and dump water in the pump basket with a garden hose. See if it pumps out. If it does then you probably have a suction side air leak since you already ruled out a suction side blockage. Pumps are pretty simple. If they run, they will pump. May be noisy, may leak, may get hot, but they pump.
