Re: Need Pump Advice, Please
Poconos,
I *think* I have already done that, but let me run it by you...
When you say to put water in the pump basket with a hose, do I need to leave the lid off and keep pouring water in WHILE I turn on the pump?
The reason why I ask is because I thought the lid HAD to be on the pump basket before I started it. Last night, I poured a pitcher of water into the pump basket, replaced the lid, and then turned on the pump. But even before I switched the pump on, the water had drained away -- presumably to the filter line??? -- so when I started the pump up, there was only about 3 inches of water in the pump basket.
Are you suggesting (and can I?) to leave the lid OFF of the pump basket and start it up with the hose pouring water in? If so, I have not done that.
I WILL say that every time I turn the pump on, it sucks the 3 inches of water out and when I shut it off, the same 3 inches of water back-flows back into the pump basket.
Does this make any sense?
I really appreciate your help!
