Results 1 to 10 of 20
Thread: When do you open your pool?
    Hot Springs, AR
    Default Re: When do you open your pool?
    Had ours open for about 3 weeks now, waters beautiful! Outside temp hit 81 degrees today and the pool is at 71 degrees so the kids and I jumped in! Once we got used to it, it wasn't that bad, but the INITIAL shock was a LULU !!!
    Cheers to all for a wonderfull summer!
    Todd
    15'X30' Muskin Fairmont, 1hp pump w/Hayward Filter
    Honesdale PA
    Just measured 8" of ice in mine in Northeast PA. Bah.
    Smile Re: When do you open your pool?
    While openig a pool is probably easier than closing one (properly), there are a couple of things that haven't been mentioned.
    Make sure all your plumbing connections at the pump/ filter are not leaking (lubing and keeping sure that any "O-rings" stay in their grooves) for unions (aka quick connections), retefloning (after removing ~most of the old tef) any threaded connections. This also includes the various air relief and drains on filters, pumps and filters. ---- Just make sure that you aren't leaking any water nor drawing any air in on the influent side of the pump. IF IT'S ~RUBBER - LUBE IT LIBERALLY WITH A SILICON OR TEFLON BASED LUBE!!!!!!
    Clean the cover (obviously - only if you covered the pool ) and let it thoroughly dry before folding it and storing it for the summer;
    1) Drying the cover on your lawn, too long, can kill the grass
    2) Fan folding (or 'sailor folding') will make the installation easier next fall (to do this get 2 people and stand at the back edge of the cover, each of you place your foot ~ 3' in and pull the cover back to the edge, step on the cover at the fold and repeat until you have a nice 3' 'fanfolded' cover, each person starts at their end and makes 2 - 3' folds until you have a nice (and easily mannaged) 3 X 3 cover which can be easily stored for the summer. ** mice and other critters tend to make their homes in stored covers - do whatever you have to to prevent this.
    If there's a lot of stuff on the deck sweep or rinse it away before it goes in the pool (optimally, this will have been done before removing the cover)
    The rest you know, remove any large debris, check your chem levels, & shock and adjust the other levels.
    Enjoy a trouble free swimming season by doing things the "poolforum way"
    I live in Iowa and I open my pool at the end of April. I get tired of looking at the covered pool. The water is to cold to swim in but this gives me a couple of weeks to get the water clear and the chemicals just right so that I can turn on the heater by mid May and swim...weather permitting of course. If nothing else, a beer tastes better looking at an open pool than a covered one!! :-)
    Central Texas
    Kept ours open all winter, but no swimming until last week. And even then it was only a few minutes.
    Since it's right outside the back, with a view from inside through three sets of sliding glass doors, I decided to keep it nice looking through the winter. It wasn't too bad to keep clean, and chlorine demand dropped way off, so maintenance was low. When it was really cold, it stayed clear without chlorine anyway.
    I drained the pumps the two or three times we had freezing weather. I still have the timers on manual, and run them an hour or two just to clean up the spring stuff falling off the trees.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
    Mandeville, LA, USA.
    Never close. Water is at 77-78 now. May hit 80 tomorrow if we get some sun.
    Dallas Texas
    We keep our pool open year round. My pool was 71 yesterday so my son and I got in. We snorkled down to the main drains with screwdrivers and removed the drain covers. Pool power was off, btw. Both drains where jam packed with leaf debris. I was in for about an hour, swam some laps too (55 laps = 1 mile), so as far as I'm concerned it's pool season here in Dallas Texas.
    47,000 Gal. Gunite, Irregular geometric shape with elevated spa
    Emerald Plaster!
    1 Aqua Logic PS8 w/SWCG
    1 Aqua Tech w/SWCG
    1 Pentair Platinum cleaner
    400,000 Hayward Heater
    Hayward Swimclear C5025 Cartridge Filter
    1 Swimmin' Lab, natch
    1 Swimmin' Boston Terrier
    Jul 2006
    Arkansas
    Ours stayed open all winter. We've kept it clean. Currently, the water is up to 75 degrees (location S. Arkansas.) Our 5 year old grandson officially opened it about a week ago when the temp was 72. His mom was worried about hypertermia, but she couldn't keep him out. He was fine. He was in and out, mostly in, and it was a hoot to watch him. I may try it at 78 or so, but last fall, I couldn't stand it below 82 degrees. There's a cool snap forecast, so we may drop a couple of degrees in the next few days.
    Jul 2006
    Pay attention to near by trees. I have a 100 yr old oak tree that is 40 to 50 feet away from the pool. I wait until the "twirly birds" are down (early/mid may) because my pool is in the line of fire. I am in NE Ohio.
    25,000 IG vinyl Utopia pool
