Thread: New Sand Filter High Pressure
    mas985's Avatar
    Pleasanton, CA
    Default Re: New Sand Filter High Pressure
    Any clean filter should not add more than 6 PSI to your total reading with 3 PSI as average so I would expect the difference between the two filters to be much less than 6 PSI. In fact, for similarly rated filters, cartridge filters should have a slightly higher PSI than sand and DE even higher. Also, most of the pressure reading in a filter gauge is due to the plumbing downstream from the filter and not the filter itself.
    With a sand filter you also add a backwash valve that can increase the pressure by as much as 6 PSI depending on the valve type. About half of that will be post filter and half pre-filter so I would expect a 3 PSI rise on the guage from that.
    So net net, I would not expect much of a rise at all between cartridge and sand. It could just be that the cartridge filter gauge was not working properly. This is pretty common so I would not worry about it too much.
    I know the filter is new but have you backwashed it yet? See if it goes down after a good backwash.
    Mark
    15-20psi is normal for my 200# sand filter with a 1hp (full-rated) pump.
    I only drop down to 7 or 8 psi when running on low speed.
    There is nothing wrong with your pump or filter.
    Jul 2006
    Thanks for the replies. The filter has steadied at about 14 PSI. All is well
    Rick
