Re: Replacement Liner for IG
I replaced mine last spring for around $850. All by myself when the wife was at work. Bought the liner from WaterWarehouse after emailing the specs to them. Not affiliated with Waterwarehouse, almost bought from intheswim but liked the pattern we have now. Just replace the gaskets from each return and the skimmer plate gasket. If you're in the least bit handy I'd do it yourself. Hardest part was putting the box in the pool, weighs around 230#. I went with a 20mil, I thought it would be easier to work with. Any extra thickness is for peace of mine.
I definitely recommend this as a DIY project. My pool company quoted me $2000 plus water which was more reasonable than yours, but I felt I could do it, and it came out perfectly.
Hope this helps and any questions let me know, Tony
Oh yeah, mine is 18X36 sport pool (3.5' on each end, 5.5' in the center) and about 20k gallons.
