Results 1 to 10 of 13
Thread: confused about solar panels (or mats)
    farmgirl is offline Registered+ Thread Analyst farmgirl 0
    Default Re: confused about solar panels (or mats)
    We have a total of four 2x20 panels, including the one that is missing the diverter in the header pipe. If we go ahead and hook it up, will it work ok? We were thinking of trying to following configuration:
    return====||>>>>>>>>>>>>>>>>l l
    l l
    ||<<<<<<<<<<<<<<<<====pump
    According to everyting I have read, the more water flow you get going thru solar panels, the better. So why do they put in those diverters in the first place? Would you not get better water flow without them, if the panels were set up and plumbed correctly? As u can tell, science was NOT my best subject.....LOL!
    Hertford, NC
    (about an hour west of the Outer Banks)
    24 foot round above ground
    well, my diagram screwed up when I sent it to the forum....let's see if i can try again:
    pump=====ll>>>>>>>>>>>>>>>>>>ll
    ll<<<<<<<<<<<<<<<<<<ll
    ll
    ll
    ll
    ll
    ll
    ll
    return====ll<<<<<<<<<<<<<<<<<<ll
    We figure that this way, if we cap off the ends with the diverters, water will be forced to path of "least resistance", and just flow one way through each panel individually. What do you think?
    Last edited by farmgirl; 03-26-2007 at 01:39 PM. Reason: correct a problem with diagram
    Hertford, NC
    i still cannot seem to get the diagram lined up correctly, but maybe you'll get the idea
    Hertford, NC
    last year i had 2 hot panels and two cold panels. The hot panels (not working properly) were the two on the inside, cooler ones were on both ends of parallel configuration. They are all the "sungrabber" models, a set of four 2x20 panels. my main concern is of cours maximum efficiency, but also whether or not i can use the panel that is missing the diverter (flow rate resrictor) in the header tube.
    Last year i had this:
    pump========
    cold==================ll
    warm=================ll
    return========
    I would like to repeat that all header pipes with diverter discs were at the return and pump side of this setup. We double checked that!
    Hertford, NC
    my diagrams are just making things worse. They are not going thru to the forum as i have typed them. Anyhow, we had standard parallel setup with return and pump on same end, and all panels capped off on the opposite end.
    Hertford, NC
    Code:
    ||>>>>>>>>>====return
    ||<<<<<<<<<====pump
    Maybe this will be a little clearer....whew!!!
    Hertford, NC
    The specifications for the SunGrabber solar panel may be found at a link to a PDF file on this web page. It says that the minimum recommended flow is 1 GPM per panel, the maximum recommended flow is 4 GPM per panel, and the normal recommended flow is 3 GPM per panel.
    Thank you for your diagram which shows that these panels are currently hooked up in series, though that doesn't make much sense since it is less efficient and would require a bypass for most of the water from the pump to go to the returns directly (do you have such a bypass)?
    The panels will hold up to 30 PSI for normal operating pressure (maximum intermittent is 45 PSI). So that's about 69 feet of head for the high-end of the range of normal operating pressure. I don't know what size of pump you have -- if you know it and the brand, then I can look up the pump curve (unless you've got the manual that should have it).
    Unless you had some sort of bypass taking some of your pump output to the returns directly and only feeding some of the flow through the panels, then it would seem to me that your pump has blown out parts of your panel (i.e. the diverter) due to higher than recommended GPM and may even exceed the panel's PSI limits.
    The specifications for these panels say that the maximum recommended flow per panel is 4 GPM. Hooking them up in series limits the total flow for the entire system to be the same 4 GPM, but the temperature gets higher as it goes through each panel. This is less efficient since you want the panels to stay cooler. It would be better to hook them up (or as many of them as is reasonably possible) in parallel instead of in series. That is, connect the tubes at one end to each other. With your four panels, that will allow for 4x4=16 GPM total to flow through the system with the panels all remaining relatively cool for best efficiency.
    On the FAQ page it says:
    How big is the SunGrabberTM System for Above Ground Pools?
    Each system is approximately 20 feet long by 4 feet wide, consisting of two 2'x20' solar panels (coupled together with a 3 ½" coupler).
    So it sounds like you have two systems which should be plenty for warming your 24 foot round above ground pool.
    Having all systems in parallel would look like the following:
    Code:
      Pump
                    Return
    I believe you were showing the systems being connected in series as follows:
    Code:
      Pump
     Return
    If one or more of your panels has a broken diverter, then that panel will likely have less flow going through it if hooked up in parallel, but you said your panels were hooked up in series so I don't see how a missing diverter would cause any problem. There would be full pressure along the entire length of pipe at the end of one panel and the water had to flow through the panel and through all other panels since in series there is no where else for the water to go. So, I'm confused.
    Richard
