Re: My pump question / Normal?
I'm sort of a newbie too, but I believe if the pump pot has no water in it, your pump is not pumping. Check the seal on the pump pot lid to make sure air is not getting in there. Sometimes my pump doesn't prime correctly after I've opened the pump pot, and I have to fill it with water and quickly put the lid back on, and start the pump, to get it to prime. It's possible you may have a leak somewhere that is allowing air to get into the lines. What's the pressure gauge on your filter say?
Of course, the pros here may be of more help, but that's my 2 cents worth.
Judy
Designated "pool girl" for 16 x 40 IG vinyl pool (installed in 2006) in S.C.
