hrsdennis
Here is where I make my big decision. If the walls are the correct size and will stretch nicely into place without wrinkles I just let the water fill. Some folks hook up a vacuum to the return opening at this point to help smooth the walls. If the walls
are baggy with way to much liner left over I use the liner like an overlap. You will need to remove the top rails again, pull the liner over the wall, use coping over the liner and the bead receivers over the coping.
