Re: Sand Filter Spec Question
The TA60D is a more robust filter than the San Dollar. I have installed both and prefer the TA60D. Pentair's web-site states that the Sand Dollar has a maximum operating pressure rating of 35psi. The TA60D's rating is 50 psi, as is the case of virtually every other filter made.
The side-mount filters are a step up from the top-mount design. They usually have 2" plumbing internally and larger laterals. The tanks are usually thicker, also.
For your pool I would recommend the TA60D. Excellent filter. If you want to use the Sand Dollar, get the SD80.
