Results 1 to 10 of 12
Thread: Sand Filter Spec Question
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Default Re: Sand Filter Spec Question
    Until a few weeks ago I would have recommended the Sand Dollar system because I'm running the SD60 on my 24' AG. Two weeks ago the tank sprung a leak on the bottom in one of the seams. Pentair told me I was out of luck because they only have a one year warranty.
    I am aggravated with Pentair since there was not one reason for that tank to crack. I live in Southern Louisiana where the pool is running all year so the tank didn't freeze.
    It might have split due to the fact that they match it with a 1.5HP pump which I had because I didn't know any better 2 years back.
    My tank problem is probably an isolated issue but I wish the company would at least have some decency to stand behind their product. The tank is clearly defective.
    Oh well I'm replacing the whole unit and going with a 2 speed 1hp pump so I should be better off anyway.
    Good luck with the upgrade. BTW is the Pentair pump a 2 speed pump? If not, and since you are going to be getting another, it would probably be a wise choice. Many around here praise the 2 speed pumps.
    Jul 2006
    Our PB says that because we have a pentair heater/pump/filter we are covered for 3 years as oppose to 1.
    Covington, LA.
    Quote Originally Posted by CanuckPool View Post
    This "may be" the case and I was under the impression that my tank had a warranty longer than 1 year. However Pentair states that they honored 10 year warranty’s up until about 3 years ago on their tanks.
    They moved to a 1 year warranty since most other brands on the market only had a 1 year warranty and according to the representative they were being burned pretty badly on the 10 year warranty deal. That statement alone made me leery in the quality of their products.
    You may want to check on the validity of the PB’s statement. Maybe they (PB) warrant it for you and not Pentair but that seems backwards to me.
    Cool Re: Sand Filter Spec Question
    Quote Originally Posted by ScottS View Post
    Scott, I don't doubt the validity of CP's statement. The PB has something that you don't - economy of scale (well, not quite, but it's the same idea). You are 1 person going at it as an individual - the PB isn't in the same situation.
    The way it works for the company for which I work:
    We buy all our pool componants and equipment from one distributer (from the pannels for the liner pools we do, the system equipment [pumps, filters, heaters, SWCGs, controls] , to the pvc fittings, replacement parts, et al.). We build 40+ pools/ year and do rehab on another 1 -2 dozen, we are 'supposedly' their biggest buyer (though I'm sure we only account for a small % of their sales. They want to keep us happy. Our supplier is only one of a nationwide company's outlets, and I have no idea how many there are, but they buy and distribute thousands of pumps, filters etc. If we send a filter back to them, they will replace it for free (reguardless as to whether the manufacturers warantee has expired). {of course this assumes that it is a manufacturing defect and not the result of the filter having been abused or improperly cared for} Just like we hold some financial 'sway' with our distibutor, the distributor's company holds an equal, if not larger, 'sway' with the manufacturers.
    -Bottom line: the manufacturers can afford to 'piss-off' one person, but will 'cowtow' to a company who 'moves'/ sells thousands of their product and may drop that line if the mfr doesn't accept a few 'out of warantee' items for free replacement.
    Proffessor Waste is done - sorry for the lecture
    Jul 2006
    I am pretty sure you are right waste. Because the PB installs X amount of pools a season he can get special 'deals' from the manufacturer, especially when it comes to installing all of their product at one time... I even have the pentair intellichlor 20 too. Which is different than buying one piece at a time as an individual.
    Covington, LA.
    Waste - thanks for the explanation, it makes perfect sense.
    I called the poolstore that I bought the system from and explained the situation to them. I was hoping they'd have some pull with Pentair sort of as you explained Waste but it didn't get me anywhere either. They are actually closing down and didn't seem very willing to want to do anything about it.
    CanuckPool - I stand corrected, sorry.
    Simsjim - sorry if this strayed off topic a bit, I'm hoping some of it is useful though.
    simsjim is offline Registered+ Thread Analyst simsjim 0
    Jul 2006
    No Prob. Some interesting stuff.
    Hey CurnackPool - You have the SD80 on a 14,000 Gal IG pool mated with a pentair 1.5 Hp superflo? Wow, that seems like a lot of pump, but then again the SD80 is alot of filter. I looked at that config and thought that was way too much for my little 12K gallons. Why did you go with such a robust system? spa? water features, etc? lots of head? Just curious.
    James
  1. Sand filter question
    By waldreps in forum Pool Equipment & Operations
    Last Post: 07-09-2011, 02:09 PM
  2. Sand Filter Question
    Last Post: 07-07-2011, 08:38 PM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  4. Changing Sand in Filter and Random Filter Question
    By newbie2pools in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2006, 03:38 PM
