Thread: Numbers question
    Default Re: Numbers question
    "Hi
    Took water sample to pool store for numbers check. Here they are:
    Free Chlorine: 3.0 good reading
    Only if CYA is no higher than 30.
    Total Chlorine: 3.0 good reading
    That's good because it means Combined Chloramines is 0.
    Calcium Hardness: 150.0 good reading
    This depends ENTIRELY on whether you have a vinyl or concrete/plaster/tile pool. If vinyl, anything from 0 to 400 is fine and 500 is manageable. If you have the hard stuff, you are too low and need 200-400ppm.
    Cyanuric Acid: 0.0 below minimum
    Is that a reading of 0 or a reading of 0 below the minimum? Either way you need to confirm that. Outdoor pools should have SOME CYA
    pH Level: 7.8 good reading
    I personally think that's too high, though technically it's OK. Water will be easier on the eyes, BUT chlorine is far less effective than when it's a little lower. I aim for 7.5.
    Total Alkalinity: 100.0 below minimum
    While Chem_Geek and I debate on this, I don't think either of us would EVER call 100 "below minimum". I would call it "perfect", he might say it's too high. But if your pH comes down to 7.5, T/A may go down too. As long as you are above 80ppm I wouldn't "fix" it because it's not broken.
    Copper: 0.0 good reading
    That's fine.
    Iron: 0.0 good reading
    That's fine.
    TDS 200.0 good reading
    Meaningless number in 99.99% of all pools with problems, meaningless in ALL pools without problems.
    In looking back at my previous sample reports, since 2005, all of my reports have had a "below minimum" on calcium hardness. I have known that, and didn't give it much todo, because I have learned on here that it is not important on the vinyl.
    I have only ever added, household bleach, baking soda, borax. I have used the pucks in the inline to raise CYA in the past. To raise the CYA I filled the inline again.
    My question is how did the calcium hardness raise? Just curious.
    Thanks,
    kathy"
    Thank you both for being so helpful.
    It is a vinyl pool. Needed a skimmer basket and had to go to the pool store, so thought while I was there I would test the water. Kind of like for s&g. (s... & giggles)
    Again, thanks
    Kathy
    Grand Prairie, TX
    I do know that calcium hardness is also important if you have a heater... but if not, I would only worry about it being over 400 or so...
