Results 1 to 10 of 12
Thread: Pool Pilot
    Ft Lauderdale, Fl
    Default Re: Pool Pilot
    Increasing the cell to an SC-60 will offer longer cell life and a linger proration warranty.
    I have an SC-48 because that's what they gave me (heck it was free).
    The question regarding the booster pump with your flow rate will be critical as the booster pump will draw water away from the manifold assembly and may result in a low flow condition, which will turn the Pool Pilot cell off.
    How many hours per day do you anticipate running the booster pump? If it's just a few hours per day of your 12 hr/day cycle, that shouldn't affect the ability to maintain your chlorine level.
    I do not recommend placing the booster pump suction downstream of the Pool Pilot manifold as the higher concentration of chlorine may (or may not) do damage to the booster pump and cleaner. I believe there are metallic components in the cleaner such as pins, shafts and screws.
    Have you considered a suction side cleaner with an in line leaf trap? The leaf trap will collect the debris before the skimmer basket, and will alleviate extra debris in your pump basket and filter. That's what I have.
    Sean Assam
    Dec 2005
    South Carolina
    Hey Catnip,
    For your reference, my pool is just under 20,000 gal and I run a 60 series cell in the DIG-220. I use power level 1, 8-10 hours of pump run time in the summer, and maintain a FC level of 4-6 (cya of 80 last year) at an output level of 15-25%. Hopefully that translates into longer cell life.
    My CYA level is around 40 this year, so I'll see what effect that has on cell output etc.
    Nater
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    Sean and nater, thanks for the responses!
    Sean, I see your point on the potential for low flow cutting off the cell with the Polaris suction inlet upstream of the cell. Can you tell me the minimum flow rate for cell operation? I looked in the manual but can't find a spec. In addition to the Polaris diverting some flow, a partially clogged filter also drops the flow as well since we currently have a pump with a "shallow" pump curve; I plan to replace it with a "steeper" curve pump that will keep a good flow as the filter clogs. We normally run the Polaris for 2-3 hours a day. And, so far, we haven't considered a suction side cleaner. We have a minimal amount of leaves and other floating debris; the Polaris does a good job of picking up sand and other debris from the bottom.
    Nater, I've been leaning toward the DIG-220 with the SC-60 cell and appreciate hearing your experience; it doesn't sound like it would be overkill at all.
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
    Ft Lauderdale, Fl
    The flow switch that we use is rated for 13 - 15 gpm minimum flow. Actually the specs indicate that the flow switch will deactivate at around 13 gpm, but may require 15- 19 gpm to fully activate. Having said that, it's difficult to specify what the minimum flow is other than giving you a general answer of "make sure you've got at least 20 gpm minimum".
    Sean Assam
    Sean, thanks. With the new, higher head pump we shouldn't have any problem maintaining 20 GPM under almost any circumstances.
    Chuck
    Default Re: Pool Pilot minimum flow
    Uhm, this maybe a stupid question, but how do you figure out what your flow rate is? I have a 2-speed pump.
    I notice that my flow rate drops when the DE filter needs a cleaning (showing ~10 psi higher backpressure at that point compared to when it's clean).
    Quote Originally Posted by Poolsean View Post
    Ft Lauderdale, Fl
    Not at all a stupid question.
    It is determined by going to the manufacturers flow charts, figuring out your total feet of head, and plotting the flow chart for high speed and low speed.
    Everyone's pump should have a flow chart to get this information.
    Sean Assam
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Absolutely, my SWCG is maintaining 9ppm FC at 10% output right now, running 8hrs a day.
  1. Pool Pilot low chlorine
    By Oviedo in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-27-2012, 06:51 PM
  2. Pool Pilot Problem
    By Graham M in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-22-2011, 02:20 PM
  3. Pool Pilot Temp.
    By jamiestone1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-16-2007, 10:16 PM
  4. Pool Pilot Setting
    By DONNIE in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-07-2007, 05:45 PM
  5. Pool Pilot
    Last Post: 08-11-2006, 04:07 PM
