Hi there
Just be sure to stick with the procedure that the others are describing. I had to bring my TA down last year and this process does work. But you need to be patient...and you need to follow the instructions. While your going thru the process think of it as if your just chipping away at the TA a little at a time by bringing down the ph...then aerate...measure measure. Bring down the ph...while still aerating...measure measure. Bring down the ph...you get the idea
Just stick with it! it does work.
Are your (bad) Combined Chlorimines gone yet?
stick with it!
dan
