Re: A bit confused
If you want to avoid a slow but steady rise in Total Alklainity (TA) from your fill water, then I would suggest that you do the acid/aeration technique with your house water in a large container and then use that water to add to the pool to fill after evaporation. It is FAR easier to lower the TA of your fill water before getting it into the pool.
Of course, whether this is worth doing is a function of how much fill water you will be adding over time. If it's a small fraction of your pool water volume, then the above procedure is not worth it.
Richard
