Thread: Super Pump II Wiring Question
    JWB is offline ** No working email address ** JWB 0
    Upland, CA.
    Default Super Pump II Wiring Question
    Hi,
    I'm exchanging an old single-speed pump with a new Hayward SP II two-speed model. The original pump was connected using three 115V wires (green, red and white). So far I've adjusted the SP II's black plug for 115V operation and connected the green wire to ground.
    On the SP II, I have a L1 spade and a L2 spade. I assume these refer to high & low speeds and only ONE should be hooked up. However, with two remaining wires, which of these (red or white) should I connect?
    Does it matter?
    Thanks...
    Upland, CA.
    Default Re: Super Pump II Wiring Question
    Gosh 1 for 4 on this forum...
    The answer is both wires (neutral and hot) needed to be connected... if anyone's interested.
