Results 1 to 10 of 13
Thread: If money were no object
    Default Re: If money were no object
    Fcfrey,
    What kind of shape is your pool? I am trying to decide whether to spring for a robot for my pool. Just want to be sure on the performance before I make a decision. Someone on another board had nothing but praise for the dolphin.
    62,800 Litre IG Vinyl
    1HP Super Pump
    Clearwater LM2-24S SWG
    250K NG Heater
    Mars HP Pool Sweep
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    Quote Originally Posted by caustik View Post
    Fcfrey,
    I have a 42x25 true ELL with hopper bottom and rounded corners here's a link to an old pix but you can see the shape.
    http://i129.photobucket.com/albums/p206/fcfrey/Pool.jpg
    The T-4 cleans the entire pool in an hour or less and I do not have to play nurse maid to it, as a matter of fact, I put it in today (under the loop lock cover) I don't have to worry about it hurting anything or getting stuck. I had a Dolphin which according to the instruction manual can't be used under 65 degrees. There is no temperature restriction with the T-4. The pool water was 46 today. Too cold for me but not the robot!!
    hzz is offline PF Supporter Thread Analyst hzz 1 star
    Toronto Canada
    That's one thing about Aquabot products-they will work in very cold water.
    The dolphin will not. Below about 65 it doesn't move around.
    Quote Originally Posted by fcfrey View Post
    . . . I had a Dolphin which according to the instruction manual can't be used under 65 degrees. . . .
    Will you, or anyone else, please confirm this quote. I am considering buying a Dolphin Diagnostic Sprite Robotic Pool cleaner and e-mailed an online store (http://www.bestbuypoolsupply.com/dol...leaners-2.html) and the technician responded saying he'd never heard of the temperature restriction. Maybe there is a difference in models. Here in the NW the pool is often below 65 deg F.
    Thanks for replys,
    Roger
    I cannot recommend a Dolphin. A lot of people here have had problems with them over the last year, myself included. They actually replaced my Dolphin with a new one because I refused to accept their explanations. My unit would not work in my pool, and they gave me a lot of BS explanations, like pH had to be 6.9, and FC really low, etc, etc. Funny, the replacement worked the way the first one had when new...
    I now have it and a Blue Diamond. I use the BD despite its drawbacks, like I have to remove my ladder or it gets stuck under it. Still the BD does a great job and the bags are just as good as Dolphin's, but far, FAR easier to clean. I never need to put it in the washing machine.
    But unless you have a rectangular pool, the BD may have troubles with the shape of the pool and you'll have to use the remote to direct it, another drawback. Since my pool is rectangular, it's not a problem. Plus the BD is super-fast--2- 3 hours to do the pool including wall-climbing--the Dolphin takes 8 hours. That means I can put the BD in almost any time and be done in 2-3 hours. The Dolphin is better going in at night or when the pool won't be used that day.
    People with Aquabots love them. Belts are easily accessible and they don't seem to have the drawbacks of either the Dolphin or the BD.
    Brooklyn, NY
    I have had my original Aquabot for 4 seasons now and I do love it. It works well in pretty much any color/temp water (sometimes my water gets away from me. ) The bag is REALLY easy to clean. I alway only use a garden hose to clean it. I did have to make a small ziptie adjustment to the cord to make sure it would not get tangled in itself.
    They claim it can run for like 10 cents a day, but I don't really believe that. When I click it on, my meter seems to spin just as fast as when my regular filter is on. I think I paid about 800 CASH for it at a pool store in NY around 4 years ago.
    Good luck!
    CARLO.
    Thanks, CarlD and Carlo. I have a 20K, IG pool that is shaped like a pregnant kidney. After reading your posts I found a Web site about the Aquabot. One w/o the shut-off timer sells for about the same price as Dophin I was considering. I'll read more about this Aquabot.
    Roger
    There are other brands. DirtDevil has one, and, if you poke around the various on-line pool stores you'll find the other brands.
    They all follow the same design--they are all spin-offs of one company in Israel. I don't know the details but there seems to have been a family conflict and other brands were created as they left the original company. No, I don't know which brand it was.
