Thread: CYA / stabilizer at stores?
    Default CYA / stabilizer at stores?
    Ok, for the standard store stuff (home depot/Walmart):
    Chlorine-Bleach at WalMart
    Alkilinity Increaser-Baking Soda at WalMart
    PH down-Muratic Acid (for my Aquarite SWG) at Home Depot
    Salt-Water Softener Salt at Home Depot
    Can you get CYA at any non-pool stores? If so, where and what form/brand?
    Any other chemicals I'm missing that I might need?
    thanks!
    (Vinyl lined, 33k gallons, Aquarite SWG)
    Indiana.
    Default Re: CYA / stabilizer at stores?
    I've seen CYA at some Walmart stores, and Lowe's too, I believe.
    Connecticut.
    I think you mean pH down is muriatic acid
    I bought a jug of CYA from Kmart a couple seasons ago. I still have some in it, and they still sell it
    -Chris
    Sorry, yes that is PH down on the Muratic Acid and I have corrected!
    The CYA at K-mart.....is this in the pool supplies or somewhere else?
    thanks!
    nc.
    It should be with the pool supplies,if ain't mistaken it has a green lid on,and says Stabilizer.....
    Margit
    Southeast N.C.
    Home of the Monster Bugs!!!
    CYA may be labeled as stabilizer or conditioner. Check the ingredient label and if it says cyanuric acid or isocyanuric acid it is the right stuff.
    Watermom
    Connecticut.
    Quote Originally Posted by Tootie
    Margit
    Yep, thats it!
    I believe the manufacturer is AquaChem.
    -Chris
  1. pool stores
    By cloudy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-16-2010, 12:52 AM
  2. Different results from pool stores-please help
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-11-2007, 04:46 PM
  3. Pool stores don't know what POLYQUAT is...
    By porkypete in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-04-2006, 07:34 PM
  4. anyone have experience with these pool stores
    By tenax in forum In-Ground Pool Construction and Repair
    Last Post: 07-15-2006, 02:27 PM
  5. Pool Stores
    By Dr. Spike in forum General Interest
    Last Post: 06-30-2006, 10:47 PM
