Results 1 to 10 of 10
Thread: pump motor overheats
    Northeast Florida, Orange Pk
    Default Re: pump motor overheats
    Sorry I wasn't clearer. The motor that quit was a 1HP with, as it turns out, a 3/4 hp impeller. Took the impeller to the pool warehouse and proved that it was a 3/4 hp by comparing it part # and physically to a brand new 3/4 hp impeller.
    Parts folks said they could see nothing wrong with impeller.
    Pump is an Ultra-Flow and the diffuser is good from 1/2 hp to 1 1/2 hp. Both 3/4 hp motors exhibit same problem, high amps, high heat, cut out operates. Voltage while pumping is 238 at motor. New pressure gauge indicates 8 psi at filter.
    We are trying to backflow suction lines. May have to find a pump to really get some flow in the lines as garden hose may not hack it.
    Indiana.
    Have you tried running the filter with the valve set to waste to see if the current draw changes or if the overheating problem goes away? Setting it to waste would eliminate a restriction (if there is one) where the new SWG was installed. When something fails and is replaced, often there was something else wrong in the system that either caused or accelerated the failure of the part.
    mas985's Avatar
    Pleasanton, CA
    It sounds as though the impeller may be for a 3/4 HP full rated motor or a 1 HP uprated motor, they are typically the same. You may have chosen a 3/4 HP up rated motor for which the impeller would be mismatched.
    What is the service factor of each motor, including the old one?
    What is important is to match the HP * Service factor.
    Mark
    Honesdale PA
    For what it's worth. It appears as if restrictions on the suction side have the same effect on current as a restriction on the pressure side. Best I could do was plumb a ball valve in the suction side and start restricting it and watching the current. If I restrict it too much the pump basket starts getting sucked dry so I avoided that. Adding just a little restriction indeed dropped the current. The jury rig I use is airtight. Verified that years ago when I first started using this old pump to circulate before de-winterizing the real equipment. I always have air in the suction side and I think what's going on is air is coming out of solution under the vacuum. I see this more with colder water which makes sense. I can only easily use 1.25" pipe so that's a slight restriction right off.
    Pump is an old Jacuzzi 1 HP SF-1 240V configuration
    Running dry -- 3.7A
    Full flow (best possible) -- 5.0A
    Slight restriction -- 4.6A and down from there.
    Attachment 662
