Re: pump motor overheats
Have you tried running the filter with the valve set to waste to see if the current draw changes or if the overheating problem goes away? Setting it to waste would eliminate a restriction (if there is one) where the new SWG was installed. When something fails and is replaced, often there was something else wrong in the system that either caused or accelerated the failure of the part.
