Results 1 to 10 of 10
Thread: pump motor overheats
    mas985's Avatar
    Pleasanton, CA
    Default Re: pump motor overheats
    It sounds as though the impeller may be for a 3/4 HP full rated motor or a 1 HP uprated motor, they are typically the same. You may have chosen a 3/4 HP up rated motor for which the impeller would be mismatched.
    What is the service factor of each motor, including the old one?
    What is important is to match the HP * Service factor.
    Mark
    Honesdale PA
    For what it's worth. It appears as if restrictions on the suction side have the same effect on current as a restriction on the pressure side. Best I could do was plumb a ball valve in the suction side and start restricting it and watching the current. If I restrict it too much the pump basket starts getting sucked dry so I avoided that. Adding just a little restriction indeed dropped the current. The jury rig I use is airtight. Verified that years ago when I first started using this old pump to circulate before de-winterizing the real equipment. I always have air in the suction side and I think what's going on is air is coming out of solution under the vacuum. I see this more with colder water which makes sense. I can only easily use 1.25" pipe so that's a slight restriction right off.
    Pump is an old Jacuzzi 1 HP SF-1 240V configuration
    Running dry -- 3.7A
    Full flow (best possible) -- 5.0A
    Slight restriction -- 4.6A and down from there.
    Attachment 662
