Re: SWG is not making pH go up
Thank you for the replies. I haven't measured TA for about a year. At the time it was in the desired range but barely. I can't remember if it was at the high end or the low end. I assumed it would not change.
I changed the pool water shortly before I added the SWG so the CYA from the dichlor is very low. I remember measuring it. The pool gets little or no sunlight so that works.
It's probably the borax then. So that will work fine for a while, but when I finally will have to add acid, I suppose I will have to add a lot!
I am wondering if there is something leaking into the loop that is providing the negative ions while slowly dissolving some important part of the pool :-|
30'x16' (irregular) indoor gunite/plaster pool, 10k gal,
Autopilot DLG-220 with SC-48 cell, 3/4 HP recirc pump,
solar panels, heat exchanger from 200 kBTU/hour Viessmann boiler
