Thread: Sand Filter from 1982 - replace it?
    Default Sand Filter from 1982 - replace it?
    Hi,
    If the water is crystal clear - does that mean the filter is working correctly?
    I was thinking about replacing the sand in my sand filter which I think is an "HRP 24", 3.1 (Hayward?). That's all I can read of the old sticker on the filter because I found out from a call to Shasta (who built the pool) that the filter is from 1982!!!!!! So I was told the sand can't be replaced, it's too old and parts are discontinued. I'd have to replace the whole filter. Great....
    The only reason I thought about replacing the sand is because:
    1. I've been running high chlorine levels all last year due to high CYA (100). I kept getting rashes on my arms the minute I came in contact with the water....
    2. I just drained the pool (2/3) to get CYA levels in check, so I can run a "normal" chem balance.
    3. I have no idea when the sand was replaced last. I bought the house 2 years ago.
    Should I just leave it be since the water is clear?
    C
    Indiana.
    Default Re: Sand Filter from 1982 - replace it?
    Quote Originally Posted by Candyass View Post
    Yes. If it ain't broke,......
    Honesdale PA
    If the old filter is working, that is, normal pressure and flow, seems to be filtering properly, no sand in the pool, leave it alone. When comes time, it has done its job and doesn't owe the pool anything.
    Thanks guys!
    Yes, it's definitely doing its job and really well. Even when I've been somewhat lazy at times the filter has kept things squeeky clean and free of algae so you're right, if it ain't broke...let the old guy be
    Thanks again,
    C
  1. replace sand?
    By duckman in forum Pool Equipment & Operations
    Last Post: 07-09-2012, 04:52 PM
  2. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  3. Time to replace sand?
    By jonno in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 10:21 AM
  4. Do you ever have to replace sand in a sand filter
    By psteward in forum Pool Equipment & Operations
    Last Post: 07-18-2006, 03:02 PM
  5. Replace the sand?
    By Saturn42 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-21-2006, 10:42 PM
