Results 1 to 10 of 11
Thread: newbie attempting to replace pool pump
    Default Re: newbie attempting to replace pool pump
    Thanks for all the info! One more thing, I have a whisperflo 115/230 pump. My previous motor was a hayward super II with a stated 230v. How do I make sure that the whisperflo is set to 230v?
    Honesdale PA
    Specific connections should be explained in the manual that comes with the pump. Sometimes the info is on the inside of the back cover of the motor.
    Schedule 40 fittings connected to pool pumps will warp if the pump overheats. Owned a pool service company for twenty years and made a small fortune repairing warped schedule 40 fitting on pool pumps (including whisperflow) installed by pool builders. Use schedule 80 fittings. The wiring diagram for the pump is on the side of the pump motor. Make sure to reconnect the bondwire to the bonding tab on the back of the new pump motor.
