Thread: Stability of Reagents for testing
    Default Stability of Reagents for testing
    I always have testing reagents left over from year to year and I keep them in a controlled environment. I never know each year what is stable enough to use again next year and what I should reorder though I have some left. Can someone out there with knowledge please advise me on the shelf life in a controlled environment for the following reagents.
    R-0871, R-0004, R-0870, R-0013, R-0008, R-0007,R-0009,R-0001, R-0002
    Thank you for your help. I have some of all of these left over some from 2 years ago or later but I don't want to use anything old that won't give an accurate test.
    Default Re: Stability of Reagents for testing
    I don't think you are going to get a definitive answer on this, but I'll give you my opinion, for what it's worth. I list below the reagents with descriptions:
    2yr R-0001 DPD Reagent #1 (potassium phosphate; sodium phosphate)
    1yr R-0002 DPD Reagent #2 (acidic organic amine solution)
    2yr R-0003 CC Indicator (potassium iodide)
    2yr R-0004 pH Indicator (phenol red)
    2yr R-0007 Sodium Thiosulfate
    2yr R-0008 TA Indicator (Methyl Red / Bromocresol Green)
    3yr R-0009 Sulfuric Acid
    2yr R-0013 CYA precipitator (Melamine)
    2yr R-0870 DPD Powder (combo of DPD Reagent #1 and #2 plus...)
    1yr R-0871 FAS solution (ferrous ammonium sulfate)
    My rough take is that the R-0002 and R-0871 solutions are the least stable and should be replaced annually. The R-0870 DPD powder life is dependent on how dry it is kept, but you can usually get 2 years out of it (it starts to look bad even before it becomes unusable). The other indicator solutions, are not unstable, but I would replace them every 2 years to be safe. Inorganic acids last quite a long time so could be kept for 3 years.
    I hope others with more experience with shelf life chime in.
    Richard
  1. reagents
    By Corrinna in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2010, 04:35 AM
  2. PS 233 - I need the reagents
    By Flagday53 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2009, 12:16 AM
  3. Chlorine Stability
    By hamop78 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-12-2006, 11:31 PM
  4. New Kit or new reagents
    By H2OLogged in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-14-2006, 01:10 PM
