Results 11 to 15 of 15
Thread: What is DE?
    Brooklyn, NY
    Question Re: What is DE?
    Quote Originally Posted by CarlD View Post
    Thanks. I only know about pool DE. Even at expensive stores it's fairly cheap, especially if you plan on using it to augment your sand filter. As I said, one 10# box was $8 and I've barely used half in 2 seasons.
    Does anyone use or have any thoughts on using DE to augment cartridge filters? I have a Jandy 580 Cartridge and would love crystal crystal clear water!
    Thanks.
    CARLO.
    Default Re: What is DE?
    Yeah, we've had some discussion on it and it's a really, really BAD idea. Apparently the DE clogs the filter permanently....
    But I also gather that the fibrous alternative to DE works very nicely in cartridge filters. Maybe something about the fibrous stuff being similar to fibrous paper in the cart?
    mikemedic is offline ** No working email address ** Thread Analyst mikemedic 0
    West Virginia
    Interesting
    Can you tell me how to add this. I went from a DE filter to a Sand Filter. How much DE to add? I assume thru the skimmer and how much PSI bump? Mine stays on 11 after backwashing. And do i need to add more after backwashing and does it ruin your sand prematurely?
    Mike
    Quote Originally Posted by mikemedic View Post
    Interesting
    Mike
    Mike,
    Usually people start with about 1/4 or 1/3 cup. You can make a slurry by mixing it with water in a bucket and adding it to the skimmer, or be lazy like me and just add it slowly to the skimmer.
    After 20 minutes to 1/2 hour, you should see the PSI rise. The object is to get it to rise 1 PSI only. So you start with a small amount and take your time increasing it until you hit your target. That's the amount to use from then on after you backwash.
    I've never heard of too much DE ruining the sand. If you add too much you just backwash it out and start again.
