Thread: pool base
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: pool base
    We looked at several options and then decided to go with what the Above Ground Pool book suggested.
    We dug out and leveled a 3 foot area all around the pool and under the deck area. Then we layed a weed block material over the whole area. The pool contractors had already treated the whole area with zapzit herbicide.
    We then filled in the whole area around the pool and deck with 5/8" washed multicolor river gravel and installed landscape edging around the outside perimeter. Were now in the process of reseeding the yard to recover from the digging.
    It took almost 10 cubic yards of gravel for the job on our 33' round pool. Some areas required 5 inches of fill. A rented Bobcat did a marvelous job of finishing up the ground leveling and gravel hauling.
    We considered mulch as the filler but research showed it draws in insects. The gravel makes a nice mud free, easy on the feet area around the pool.
  1. questions about repairing vermiculite base in older in-ground pool
    By Glove in forum In-Ground Pool Construction and Repair
    Last Post: 07-03-2012, 12:26 AM
  2. Base for an Intex Easy Setup Pool
    By Wisewr in forum Intex-type Pool Setup & Operations
    Last Post: 06-01-2012, 06:28 PM
  3. Base for an Intex Easy Setup Pool
    Last Post: 05-20-2012, 07:24 PM
  4. Pool setup question - Base for pump/filter
    By Jacob99 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2012, 03:07 PM
  5. Pool base styrofoam
    By Lauralai in forum Above-Ground Pool Construction & Repair
    Last Post: 05-30-2008, 02:24 AM
