Thread: Solar Panel?
    csevel is offline Registered+ Thread Analyst csevel 0
    Cleveland, OH
    Default Solar Panel?
    I have a friend who wants to give me a solar panel approximately 4' X 8' and I was wondering if this panel alone would be worth putting on an 18' above ground pool?? (7600gal)...would I need more than one?
    Default Re: Solar Panel?
    We had a 2x20 solar panel on our 18' round 48" high pool the last 4 years. It kept the pool at a comfy 82 degrees most of the time (Mid July it got TOO hot, so we used a diverter to bypass the panel) We live in the far North so take that for what its worth in the calculations. I wouldn't go with less than 2x20 amount for that size pool, it may not keep up. A solar blanket on top is MUST to keep the heat IN, especially at night. Its way harder to heat back up from a cooled off pool than to just maintain the temp.
    Cleveland, OH
    I mistyped...It is 4' X 10'. Wouldn't that be exactly the same square footage? I do have a solar cover for nightime.
    Yes - same area.
    Watermom
  1. How much of a PSI increase with solar panel?
    By jmjbj_h in forum Pool Equipment & Operations
    Last Post: 05-22-2007, 12:21 PM
  2. Solar Panel Install
    By MaxxFusion in forum Pool Equipment & Operations
    Last Post: 06-17-2006, 06:14 PM
  3. Solar Panel - too much air in system
    By jmcst25 in forum Pool Equipment & Operations
    Last Post: 05-27-2006, 09:33 PM
  4. solar panel
    By marchbreak in forum Above-Ground Pool Construction & Repair
    Last Post: 05-03-2006, 09:13 AM
  5. Solar Panel Options?
    By JWB in forum Pool Equipment & Operations
    Last Post: 04-13-2006, 10:00 PM
