Re: SWG and Puck Feeder?
Waterbear, PoolSean, CarlD, et al, thanks for your wisdom on this. Actually, my original question was slightly different, but you answers were all helpful.
The original question dealt with any danger associated with leaving a puck tri-chlor feeder in line with an about to be installed SWG system with the puck feeder to be used as a backup in case the SWG had to be out of service for more than a few days. As I said, I'm away from the pool for many days at at time and, unfortunately, up to now I've had to rely on the puck feeder when I'm gone. So, I was looking for a way to quickly switch back to the puck feeder until I have the opportunity to get the SWG up and running again.
Based on all your responses, I think I'll remove the puck feeder and fit it with a pair of unions such that it's an easy drop-in replacement for the SWG cell. Total Cost = $15.
RE: replacement parts for the SWG; none of the local NW Florida (that's where my pool is located) pool stores nor distributors (as far as I can tell) carry the Auto Pilot line and I suspect there isn't a service center within 50 miles either. Conversely, I can get a pump, filter and other common parts within a hour. So, that's why I'm being a bit conservative in looking for a backup for the SWG.
Again, thanks all for your feedback, ideas and suggestions!
Chuck
16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
