Results 1 to 10 of 13
Thread: Cost of Water
    Default Cost of Water
    Hi All,
    Having the liner replaced in my IG this spring and was shocked at the cost of water.
    We are on a well, and there is no way I am going to attemp to fill 26K gallons from it.
    So we are left to have water delivered. Best price we have found is 50 dollars per 1000 Gallons!!!!
    I've checked with local fire companies and municipalities for alternative, but they no longer do this because of liability issues.
    Does this seem resonable or am I just out of my mind on what water costs?
    Scott
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    Default Re: Cost of Water
    What's the reason for not using the well to fill the pool? I have a similar setup in NW Florida and it's way cheaper to pay the electric bill to pump well water than the water/sewer bill to use city water. It will probably take a bit longer to fill from the well than having water hauled in but I would guess no more than a few days total to fill.
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
    Quote Originally Posted by catnip View Post
    We only have well water at our house. There have been two wells that have gone dry in the neighbor hood this past year. Also the neighbor down the street tried to fill his pool from the well and killed the pump.
    I called a well drilling company in the area and they advised against it. The estimated for a house of 4 we consume around a max of 400 gallons per day. So they said we would pump more in two / three days than we would in two months normally. Said pump is not setup to run that constant and we could severely dent our water table.
    I guess I am just not willing to risk my well to fill the pool.
    Scott
    Now I understand; I, too, would not want to risk my household water source! Fortunately, in our case, there seems to be plenty of well water available, and we use it every day for irrigation of the lawn.
    Chuck
    Wonder what it would cost to rent an empty tanker, pump the water into it while replacing the liner then dump it back into the pool - might be less than the $1,300 for buying new water.
    Ocoee, Florida
    Check with your local water company for they might not charge you for sewer cost, just the water when filling a new pool. My PB gave me a letter stating my fill date and the amount of gallons used to fill. I took it to my water company and was not charged for the sewer portion on that bill. Saved me a boat load on my water bill. If your using a PB to install your liner check with them.
    15,000 gallon IG free form 16x32 w/attached IG 6x7 spa. Aquapure SWG, Jandy Aqualink 4 w/ PDA, Paramount infloor cleaning system, Starite 400K propane heater, Starite system 3 filter, Starite 2hp pump, polaris D'Light LED pool and spa light and paver decking. Completed in 11 weeks 7/4/06.
    Tanker only holds 6K of water, so I would need 5 of them to get all the old water out.
    Also, to drive this you need a CDL.
    The 1300 is basically paying for the cost of the truck, driver and delivery...and a little for the water.
    Also,
    I live in the country (about 60 miles nw of philadelphia) so there is no local water or sewer authority.
    I have checked with the local fire departments, truckers union and township office. So far, I have found one company (same one the pool company recommends) that provides this service.
    Scott
    Jul 2006
    SE Georgia
    Quote Originally Posted by swreeder View Post
    ...Also the neighbor down the street tried to fill his pool from the well and killed the pump. ...
    I did this too, only to find out I just tripped the overloads in the pump control box. I had inadvertently pumped my 40K gal pool down about 4 feet when I left the filter valve is waste and went to Lowes. The timer turned on the pump and, a couple of hours later, pool was way low. I turned on 4 water hoses and had them going into the pool. About an hour later, NONE of them were running. Come to find out, pump was turning on and off rather quickly as tank depressurized due to the 4 hoses. Once I figured out it was the overloads and not a burned up pump (whew), I came straight off the well head with a 1-1/4 inch PVC fitting, some 1-1/4 inch PVC pipe and my vacuuming hose and filled the pool in short order. Because I bypassed the tank, it never re-pressurized and the pump never cut off until I stopped it manually with the pressure switch. Since the pressure was going to be low due to the big open end of the hose, all I did was press fit the PVC pipe together and, it didn't leak. It pulled it back apart when I was finished and saved it for another day.
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
    Jul 2006
    We are in PA about 100 miles west of Philadelphia . We got 14000 gallons for $700 - 800 , don't remember exactly . Made up the difference with the well , about 6 - 8k gallons . Didn't like using the well all that much either but, suffered no consequences .
  1. cost
    By sunofthebeach in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-30-2011, 11:42 PM
  2. Low cost Filter for water feature pump
    By Big_D in forum Pool Equipment & Operations
    Last Post: 03-20-2007, 04:52 PM
  3. In Ground Pool Cost - Which Cost the Most?
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2006, 05:31 PM
  4. Cost?
    By Archer in forum In-Ground Pool Construction and Repair
    Last Post: 08-02-2006, 07:44 PM
