Thread: Old solar cover disposal
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Default Old solar cover disposal
    My solar cover will be going on it's third year this season and from what I hear it'll be approaching it's end of life. It actually looks pretty good still so I'll stretch it out if I can. But it's a blue and silver model so there's little light penetration and in Upstate NY we need all the solar gain we can get, so I'm also leaning to retiring it soon for a clear one.
    Anyhoo, are these things recyclable? I hate to just toss it in the trash.
    Chuck
    Default Re: Old solar cover disposal
    unless it's got the recycle logo on it, you're likely going to be hard pressed finding anyone who will take it.
    Try calling your local recycle center and they should be able to tell you, if someone tells you yes - get their name, because htere's nothing worse that showing up to drop it off and the next guy tells you no.
    Honesdale PA
    May be handy to cut some of the good sections and save them for maybe covering sections of the pool that the regular cover doesn't cover or cushions to lay things on like a rolled up solar cover. If you have use for these good sections at least it will cut down on the quantity of what you need to trash. As a last resort if you're into bonfires the stuff melts down to nothing.
    My old liner and old solar blanket made great underlayment for the rock garden I installed around the pool perimeter.
    Duanesburg, NY
    Thanks all, I'll try to recycle and if that fails I'll reuse creatively. If I can recycle I'll report back.
    C.
  1. Intex debris cover or solar cover
    By Larryh86GT in forum Pool Equipment & Operations
    Last Post: 06-12-2013, 06:06 PM
  2. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 02:45 PM
  3. Solar Cover as Winter Cover?
    By CoffeeBean in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-02-2007, 11:46 AM
  4. Where to buy solar cover
    By noworries in forum Pool Equipment & Operations
    Last Post: 09-24-2006, 09:29 PM
  5. Solar cover under winter cover?
    By margekendall in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-18-2006, 10:49 AM
