Hello everyone - been a while since I've been on the forum, it's nice to see familiar names are still here helping out. I've been maintaining my pool in the BBB style since we finished it 0 months ago and have been pleased. I got a bit complacent the past 3 months or so and didn't test/balance water as regularly as I should have. Several times the PH crept up +8.0 and chlorine got very low but I managed to bring it around. The water remained clear, no algea that I could see, etc.
However, now the water is warming up (yes - here in Miami I think water temps below 88 are COLD!) my kids are using the pool and I'm back to testing/balancing regularly the past week. I think I have a problem with Calcium Hardness. First, some numbers from this evening 6 p.m:
Cl 2.2 TC 2.2 Ph 7.6 Alk 80
CYA >30 CH 525 Air Temp 80 Pool Temp 78
Today I added some stabilizer to bring my CYA to 30-40 range. Then I'll bump up my CL numbers to 5-6. I ran the pool at these target numbers last summer and was happy with the results. My Alk ia consistently between 70 - 90. In November, my CYA was at 30 and my CH was 350 - last time I tested those two. Thought I could get away without testing those in the winter.Have added water a several times, couple of inches throughout the winter, no significant rain fall.
Now my Ph creeps up constantly (newish pool!) and from day one I've had to add acid regularly to keep it at 7.6. I admit I haven't been consistent with maintenance this winter. I have had several instances where PH crept up too high(+8.0) before I caught it. In response I think Iadded too much acid all at once to bring it down to 7.4. The "bring Ph down gradually" rule was lost on me until now. Not sure if this contributed to the current problem.
Now to my main problem with CH test/results (besides the incredibly high number).....
1) when I add the 5 drops of R-0011L Calcium Indicator, my sample turns decidedly pink not red. Is that a problem?
2) when adding the R-0012 Hardness Reagent, obviously my sample does not change from red to blue. Instead the pink color seems to "break up" into little particles floating in the water sample. I keep adding drops/swirling and eventually the water does begin to turn blue but the floating pink particles remain in suspension - reading at 525. What is happening/has happened?
BTW, my fill water tests at 90 and there are no floating particles so I don't think the problem lies with the age/quality of the reagents, right?
I know I need to drain and refill to lower CH but beyond that, these particles and what they represent have me worried....
Also while the pool water looks clear to me overall, when I conduct the chlorine test it and the water turns from pink to clear, the water in the tube seems cloudy. Is this significant?
And lastly - today I noticed a few brown stains on the walls of the spa, each a couple of inches in diameter, right by the steps. Are they part of all this?
Sorry this is kind of long but I've tried to give a complete picture - can anyone help? thanks in advance.....
Gracy
