Thread: Heat pump- impact of ambient temperature on operation
    Default Heat pump- impact of ambient temperature on operation
    Does anyone have some information on the relative efficiency of a heat pump based on ambient temperature? I have an 80,000 BTU/HR rated unit that I have been operating at night as I have cheaper electric power at night. I am wondering if I am actually saving money or if I would be better off running it during the day when the temperature of the air is warmer. Anyone have some insight into this?
    Ft Lauderdale, Fl
    Default Re: Heat pump- impact of ambient temperature on operation
    Cleancloths,
    Although the efficiency of the heat pump will be reduced at night, it is still very efficient. The best thing you could do is to put a solar cover over your pool. Night time is when you loose the most amount of heat and a solar cover will help retain most of what is lost to the ambient air temperatures.
    Most Heat Pumps will maintain sufficient amount of efficiency even when ambient air temps fall into the 60's. Below that and some systems, if they do not have the hot gas defrost cycle, will shut down when the outer evaporator fins ice up.
    When you get down into the 50's or colder, efficiency starts to drop.
    Sean Assam
    Mine will go into defrost mode if it gets too cold. What I am talking about is running the system in April/May Sept/Oct when outside temp at night can be in the 30's and 40's. It sounds like I might be better off running it during the day at those times when the temperature is in the 60' nd 70's.
  1. Replies: 3
    Last Post: 12-15-2012, 12:44 PM
  2. Can temperature sensor replacement on a heat pump be a DIY project?
    By dawndenise in forum Pool Equipment & Operations
    Last Post: 05-12-2011, 04:22 PM
  3. Dynamic head, SWCG and 24/hr pump operation.
    By sailork in forum The China Shop
    Last Post: 07-11-2006, 03:44 PM
  4. Air Temperature Need For Effective Solar Heat
    By Xndman in forum Pool Equipment & Operations
    Last Post: 05-19-2006, 12:32 PM
  5. polaris 380 and pump operation?
    By buck1s in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-25-2006, 08:48 PM
