Thread: Heat pump- impact of ambient temperature on operation
    Ft Lauderdale, Fl
    Default Re: Heat pump- impact of ambient temperature on operation
    Cleancloths,
    Although the efficiency of the heat pump will be reduced at night, it is still very efficient. The best thing you could do is to put a solar cover over your pool. Night time is when you loose the most amount of heat and a solar cover will help retain most of what is lost to the ambient air temperatures.
    Most Heat Pumps will maintain sufficient amount of efficiency even when ambient air temps fall into the 60's. Below that and some systems, if they do not have the hot gas defrost cycle, will shut down when the outer evaporator fins ice up.
    When you get down into the 50's or colder, efficiency starts to drop.
    Sean Assam
    Mine will go into defrost mode if it gets too cold. What I am talking about is running the system in April/May Sept/Oct when outside temp at night can be in the 30's and 40's. It sounds like I might be better off running it during the day at those times when the temperature is in the 60' nd 70's.
