Hi everyone, and thanks again for your advice last season!! I saved a ton of money and headaches!!
I am getting ready to open up and clean my Hayward Perflex DE Filter (EC75A).
In the owners manual it states: open up, soak in 1:1 ratio of 20% muriatic acid, then flush with water.
My question is does the flex-tube assembly come right out? How long do I soak it for? And, what should I look for once the assembly is out?
Thanks.
), but it would be OK to use, IF you only fill the washing vessel enough to soak only the fingers (I'd have the level be ~ 1/2" below the tube sheets - the metal parts will be quickly damaged in that strong a mixture!) I'd imagine that 1 hour would get anything on the fingers off, though it would help to gently turn the nest a couple of times while it's soaking to insure that everything gets 'acid-ed'.
) Charge the filter with the proper amt of DE and enjoy the pool season!! (If you need a little info on evacuating and recharging the DE - just ask here and I'll link up some advice I gave last year)
