Thread: pump and light
    Honesdale PA
    Default Re: pump and light
    Here's a couple threads that may be of help with the pump motor issue.
    http://www.poolforum.com/pf2/showthread.php?t=4800
    http://www.poolforum.com/pf2/showthread.php?t=6641
    got the pump working by doing as you suggested with the impeller. thank you. that saved me alot of money. haven't worked on the pool light yet. need to clean up the pool first. it's a little green. which brings me to another question on how to begin to add the bleach or how to get started... after i get it vacuumed, do i add the bleach and get the chlorine adjusted? should i add the polquat at the same time as the bleach? thank you
    Red face Re: pump and light
    PH101, sorry to have missed this for a week . If it's not too late; hold off on the algicide until after the water is clear and CC free.
    Algicide is slightly mis-named, it's more of a preventive measure than an algae killer, for killing, you want chlorine, and lots of it. Keep the free cl level up to 'shock' level consistantly until the algae goes away (as shown by having no CC) and then let it drop back down to normal - at that point you can add the recommended dose of poly60 to help keep the algae from getting a 'foothold' if the chlorine level isn't kept up for a while.
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. Can't get the light out!
    By terpsucka in forum In-Ground Pool Construction and Repair
    Last Post: 08-31-2010, 10:12 PM
  3. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  4. What do I do with my light?
    By poolbee in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-18-2006, 04:57 PM
  5. Where to put new light?
    By jeffguay in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2006, 07:55 PM
