Results 1 to 5 of 5
Thread: Cloudy water
    Alabama
    Default Cloudy water
    Here are my numbers from the pool store:
    CYA: 25
    Free Cl: 2.5
    Tot Cl: 2.5
    pH: 8.4
    Alkalinity: 151
    Hardness: 246
    I have a 23,300 cement IG pool with a sand filter. Water is not that bad, I can see the bottom at the shallow end but cannot in the deep end.
    What can I do to get this crystal clear?
    Default Re: Cloudy water
    Shock your pool and maintain shock levels for a few days. See the 'best guess' chart at the following link to help with shock levels. Run your pump 24/7. Also, use some muriatic acid to lower your ph down to about 7.4.
    Watermom
    http://www.poolforum.com/pf2/showthread.php?t=365
    Alabama
    Where is the best place to buy that?
    duraleigh Guest
    Quote Originally Posted by Xignals
    XIgnals,
    I assume you mean muriatic acid. Lowes..Home depot.
    Down mwsmith2's calculator from any of his posts so you won't put in too much. In fact, I would get it in there immediately...it may be the cause of your cloudiness and is certainly not helping your pool.
    Alabama
    Off to Lowe's right now!
    Thanks for all the help!
