TDS of 1000 ppm is not too bad. Total TDS - Salinity = Potentially harmful TDS.
It's a good idea to test your source water, especially for TDS as this should be considered your NORMAL TDS, which should fall between 300 - 700 ppm. These are mostly calciums, magnesiums and metals. When these levels increase to 1000 ppm HIGHER than your normal TDS, then you should consider draining. However, when you have high TDS as a result of the harmful ingredients, your water will also appear dull and cloudy, with a metallic taste to the water, AND your chlorine will be less effective.
High TDS as a result of salt is not harmful.
It is possible for the salinity to be 3500 + ppm from your softwater system. However, that level will be too high for the AquaRite, so in this case, Leslie's is correct in recommending that you drain (not you do not need to do a full drain, just a partial drain will do). Then refill with the water not from your water softener system. You'll just be adding back in the salt.
On a Taylor test kit, it's difficult to distinguish 0 ppm from 23 ppm, but assume that your stabilizer is too low and will need to be added. You want to get to about 60 ppm to 80 ppm. The normal dosage is 1 lb / 5,000 gallons increases 25 ppm.
Alkalinity is high and so is pH so adding acid and aerating should do a good job a lowering both.
Calcium is good, thank God for Water softeners.
Definately treat for Phosphates. The water will get cloudy for a few days as a result, but it is to be expected with phosphates in the pool. Clean out/backwash the filter after the phosphate treatment (when the water gets clear).
The dust storms should not cause an increase in TDS unless you're located close to a golf course that is constantly fertilizing...but that should affect the phosphates more than the TDS.
