Top your pool off, get your pump and filter running and then maintain your chlorine at shock level (based on your cya reading). Test it three times a day if you can, and each time add enough bleach to bring it back to shock level. Also, run your pump 24/7 while you are trying to clear your pool. Also test your ph to make sure it is somewhere between 7.2-7.8 with 7.4-7.6 being ideal.
