Re: FAS-DPD Test
elsie
There is one more thing you could help me with. I don't understand Step 1. of your instructions. It simply doesn't compute, i.e., what does it mean "For 1 drop = 0.2 ppm, use 25 mL sample. For 1 drop = 0.5 ppm, use 10 mL sample." I must not recall this from Ben's 2005 kit or we just didn't have the option. In any case, this will clearly become important because of the 'drop equivalence' in Step 4. Can you expound on for my brain block? Thanks again -
If you use a 25ml sample, each drop you add in step 3 represents .2ppm FC (this is the 'drop equivanlece') so multiply # drops in step 3 by .2 to get ppm FC.
Same for step 7... for a 25 ml sample, drop equivalence is .2
If you use a 10ml sample, each drop represents .5ppm FC. This method requires fewer drops, but would also be slightly less accurate.
~Grace
Avid reader of this forum
but alas, no pool... yet!
