Results 1 to 10 of 12
Thread: Opening Numbers
    Bucks County PA
    Default Re: Opening Numbers
    I copnfirmed this morning with my Taylor kit that the CYA was 100. Dumped about 12 inches of water and currently refilling. I hope to see the number drop to at least 70.
    Bucks County PA
    UPDATE
    I drained 12 inches of water yesterday in my 16x32 pool with a deep end and replaced it with "Fresh" water. My Taylor test kit still says 100 CYa and the pool store says 105 CYA. Is it possible to remove that much water and still have the same CYA?
    What is going on?
    If your average pool depth is 4.5 feet (which is usually the case if your shallow end is 3 feet and your deep end is 6 feet), then a CYA at 100 should get reduced to around 80 (even if your deep end is 8 feet, the drop should be similar). 100*3.5/4.5 = 78; 100*4.5/5.5 = 82.
    The CYA test is hard to measure at the higher CYA levels as you can tell from the closely spaced lines on the tube at higher CYA. I suspect measurement variation or error more than anything else. Either that or the CYA was actually more than 100 (since 100 is the highest the turbidimetric test measures).
    I would just do another drain/refill and you should see a drop.
    Richard
    Bucks County PA
    Yes that will have to happen again. I too was thinking maybe the CYA was higher than 100. The lady at the pool store said their test goes up to 120 or 130 so I am wondering why their first test said 105 and did not read higher. Only thing it could be error in reading their test.
    I will keep you up to date.
  1. Opening numbers are in...
    By PBLsQuad450 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-26-2012, 03:06 PM
  2. my numbers after opening
    By roady in forum DPD-FAS based testing
    Last Post: 05-25-2008, 09:43 AM
  3. Opening Numbers
    By BigStein in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-07-2008, 10:12 PM
  4. Opening test numbers...what do I do now?
    By okpool in forum DPD-FAS based testing
    Last Post: 05-16-2006, 11:02 PM
  5. Opening numbers
    By Poolidiot in forum DPD-FAS based testing
    Last Post: 05-13-2006, 09:38 PM
