First of all take a deep breath and know that your pool will be cleared up soon. You have to know that the best thing to clear a pool is POP which is pool owners patience. Now I will try to address what I think is going on with your pool.
If there are metals in the water and you shock a pool, it could cause the metals to fall out of the water and land on the surface of the pool. If you get some stains the best thing to do is to lower the ph to 7.0 add sequesterant (most of them are good) and let the filter run 24/7. Somethimes the low ph along with the sequesterant is enough to lift the stains back into solution which the sequestering agent will then bind with the metals and keep them suspended. Your water probably got cloudy because the metals were lifted off and this is in the water now - it will take a while to clear. You can add a chlorine puck to the skimmer since you have a sand filter. You can turn your return jets up to bubble on top of water so that your alkalinity(which is high) will lower while raising the ph. When the ph gets back to 7.4, add some acid to lower back down to 7.0 and keep the jets facing up. This is how you lower alkalinity. As your alkalinity is lowered, your ph will go up. If after a few days you still see some stains let me know, you can then get some ascorbic acid to remove the remainder of the stains and I will give you the directions on how to do that if you need to.
One of the ways metals fall out of the water is with high ph and high chlorine. So you may want to keep your ph at the low end for a while, and make sure you keep a constant level of chlorine in the water so that you don't have to shock.
If you have any questions, please feel free to ask - once you get your water balanced it will be easier to keep the stains away. Always keep a sequestering agent in the water - so if you add a lot of water make sure you add enough sequestering agent. I also find that using regular bleach is easier when you have metals in the water, because you can add the bleach slowly with more control. It is also a good idea to put a puck in the skimmer while getting rid of stains, because the water will hit the chlorine puck and if the metals fall out they will fall out onto the filter before they hit the pool. Just make sure you don't pour the bleach on the puckAdd the bleach in by the return jets. Let me know how it goes
