The part number on the Intermatic Time Clock, T104, indicates that it's for 220 volts. The motor that activates the mechanical switch is specifically 220 volts, so it shouldn't be 120 volts.
Sean Assam
e-mail: [email protected] --- www.autopilot.com - www.aquacal.com
I switched the lead to load 2.
Now i can turn the pump on only with the manual lever behind the timer wheel.
If the pump is off (by that lever) i CAN turn the pump on and off using the toggle switch.
The x-10 remote does not work.
Now that i think about it, he "pump switch"( kind of a flat switch) is an x-10 switch.
So the must be some wiring going on somewhere to enable that to work.
I think then i should put that lead back, but wire the aquarite to load 2 and 4.
I would recommend finding out the load capability of the X-10 unit to ensure that you don't over do that device. Most likely you'll have enough amperage on the X10 to connect the pump and Aquarite. Therefore, I would recommend that you connect the Aquarite to the SAME terminals that the pump is connected. Just remember though, that one line is constantly HOT and sending power through it...which means be careful!
Sean Assam
I have an electrician( who does all the work for a local pool store that i trust) coming this following afternoon to just take a look.
The ratings for the switch should be one it somewhere would guess.
That said, it wont HURT the aquarite to have constant power on one lead all the time then?
I suppose it is only turned on by the flow switch so it should'nt.
i do appreciate all your input.
BND, no problem. Thats what this site is all about. The flow switch is a UL1081 required safety device. Having one line constantly powered will not harm the system.
Sean Assam
All set, seems to be working fine, thought salt levels are a bit low.
Going to have that checked again and hopefully be set !
Thanks for all the help Poolsean
