My 18x36 AGP is hard plumbed with PVC. I have the ability to remove the pump via clamped connections on the skimmer side, but on the return side of the filter, *everything* is glued. That's the way it was installed.
I would like to add a couple of solar panels, but from what I have read, they need to go on the return side. That means I am going to have to cut the PVC and install some fittings.
While I am comfortable working with PVC in general, the thought of cutting the hard plumbing scares me. I guess I would just like to know if anyone has actually done it. And if I have to cut and paste, would there be any benefits to replacing the entire return run instead of just inserting fittings?
Any suggestions, recommendations, or just plain encouragement would be appreciated!
Linda
near NW Houston
Just cut and glue. Use primer and then put cement liberally on both sides of the connection. Wait a few seconds then insert pipe into fitting with a twisting motion and press firmly and hold for about 10 seconds and you are done.
