You should be checking the chlorine and adding as required. Your pH is most surely not 9-10. Probably an artifact of the high chlorine interfering with your test.
Post your numbers for chlorine and CYA to get better answers. It will clear up.
Thanks for the quick reply!
I made a mistake in the post. My Chlorine is 9-10, not the PH. The Ph is about 7.5. The alk is slightly above normal.
I am currently using the HTH 6-way test strips so the reading is not 100% accurate. I will be getting a better test kit.
In the meantime, should I just keep dumping and will it eventually clear?
Thanks!![]()
HELP!!!!!! WHEN IS THE MADNESS GOING TO END? I MUST HAVE POURED 25 JUGS OF BLEACH! ARRGHHHHH
DAY 3.....![]()
Try going to a pool store and buying a couple of 5 gallon carboys of Liquid Chlorine at 12.5% (there's nifty nozzle you can get that fits the carboys that's great). Each carboy will be like adding AT LEAST 10 gallons of 6% bleach.
It will save you lots of empties and (with the nozzle) is easy to add.
You'll need to give a deposit on that carboys, but I've been recycling them for 4 years now on the original deposit!
Check pricing: to be worth it, A Carboy shouldn't cost more than 10 gallons of 6%. If it's less, it's a good price.
You need a LOT of chlorine, but at least this may make adding it all easier.
Thanks, Carl! If I don't get a carboy, I'll get some of that 12% liquid chlorine from the pool store and dump a couple of those in at a time. I have a couple dozen empty clorox containers in the recycling bucket already -- the recycle guys are going to be cursing me! haha
Hopefully a couple/few more dumps of bleach will clear the pool!
You need to know your CYA level, and then get your FC level up to shock level using this chart. Keep testing your water, several times a day, if possible, and keep your chlorine at shock until your water clears.
Plan on replacing your filter cartridge after your conversion is complete
~Grace
Avid reader of this forum
but alas, no pool... yet!
One of the poolforum guys that lives near me did the conversion a couple years ago and I watched part of it. As I recall he kept dumping bleach and seemed to have no effect then all of a sudden...bingo. Pool cleared in a few days. He also had a mountain of bleach bottles. Be patient and persistant.
