Results 1 to 10 of 13
Thread: Adding Bleach w/CYA in skimmer?
    Columbia, SC
    Default Adding Bleach w/CYA in skimmer?
    Is is okay to add bleach while I have a sock w/CYA in the skimmer basket? ( I plan to take the sock w/CYA out & hold overnight in a bucket and restart the process tomorrow.) Thanks in advance for your folks out there. Soon to be swimming, Joyce. p.s. I have only one skimmer because the other is plugged.
    18,000 IG Gunite/Plaster, Hayward Sand Filter
    Default Re: Adding Bleach w/CYA in skimmer?
    Yes, you may add bleach to the general body of pool water, probably over a return, while you have CYA in your skimmer. CYA and bleach are quite compatible. In fact, Trichlor and Dichlor are simply compounds of the chlorine from bleach plus CYA. I wouldn't pour the bleach into the skimmer, but that's just because it's better not to have concentrated chlorine flowing through your heater, pump and filter.
    Richard
    Columbia, SC
    Thanks CG! As usual, you folks are great! Happy Swimming
    I always pour my bleach through the skimmer and it doesn't hurt a thing. And, so does Al (Poconos). Of course, only when the pump is running. It is diluted so fast with such a large volume of water and is dispursed so quickly that it is not a problem.
    Now -- I probably wouldn't pour the bleach over a sock full of cya but otherwise, it isn't a problem. We have both done it for years.
    bcb1 is offline ** No working email address ** bcb1 0
    Yep, always use a sock or woman's nylon to add cya. No problem with pouring bleach in the skimmer - but I usually just pour it in the deep end of the pool.
    Watch your cya level -- you can always add more stabilizer, but you can never get rid of it if you have too much - unless you drain the water.
    South Carolina
    Pouring bleach directly into the skimmer is pretty hard on the pump seal. If it's old, that may make it start squealing.
  1. adding bleach
    By kev6262 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-11-2012, 06:17 PM
  2. How often should I be adding bleach?
    By Charles in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-27-2011, 01:45 PM
  3. adding another skimmer and return
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2007, 10:50 AM
  4. Adding bleach to the skimmer
    By trauh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2006, 03:07 PM
  5. Newbie Question “what is adding a sock” to the skimmer
    By slater1182 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-07-2006, 01:23 PM
