Hi All,
I'm Installing a new pump and the PB didn't leave me any room to replumb. The valve only has 1/2 inch of free pipe before there is an elbow, which needs to be cut off for the new pump. I'm curious if it's possible to separate the PVC from the valve and start new or if the only way to do it is to replace the entire valve assembly. I don't want to do that though as it will be a TON more work.
Thanks for any advice.
Joe
