Better yet, plumb it with PVC if you can.
There's a simple screw-in fitting on the filter for the backwash that can be replaced with either 1.5" or 2". I replaced it with 2" because the heavier backwash hoses are 2" and that's mine.
I just hose-clamp it on.
Mine popped to.....3 times.
After the second hose I plumbed mine with pvc and it works great!
I just received a 2" hose, to find out that my old hose is 1.5", can I just use the 2" w/o any adjustments and just clamp it back on as it was on the 1.5"?
Yes I am a newbie
Grecian 17'x33' Vinyl liner pool
ZeoBrite filteration
SWG Aqua-rite
Sta-Rite Dura-Glas 1.5hp pump.
SAM Light
21037.5 gallons
That should be no problem to do, but I hard piped mine as well, much nicer looking. I have it piped into a drainage pipe underground.
I bought a 1.5 inch firehose off ebay; it'll last a long time only using it 6 or 8 times a year. I got one or two backwashes out of those silly PVC hoses before they parted.
