Thread: Can't Get Rid of Green!!
    jmjbj_h Guest
    Default Can't Get Rid of Green!!
    Maybe I am just at a lack of patience, but it has been a week tomarrow and I still have a green pool. 16x32 IG Vinyl
    TC 10 to 15 ppm, for a week
    FC 10 to 15 ppm
    CC neg
    TA 80
    CYA 0
    PH 8.0-8.2
    I have been following the rule to a tee, testing and keeping my clorine levels up with bleach, running the filter day and night, and continuously running my Dolphin. It is a teal green with quite a bit of turbidity. Any suggestions?
    Default Re: Can't Get Rid of Green!!
    If your pool has algae I doubt that your TC and your FC are both at the 10-15 ppm range. I suspect that your are testing with OTO (turns yellow in the presence of chlorine) and that only tests total chlorine, not free chlorine. While you might have a high total chlorine reading your FC is probably near 0, if not 0 and it's the free chlorine that kill algae! If the pool has algae then you will have combined chlorine if there is clorine in the pool! IF you are only testing immediately after adding the chlorine then you will possilbly be showing a high chlorine level and no CC but if you test a few hours later you will find the readings have changed a lot! Please let us know how you are testing (OTO--turns yellow and uses a color comparator, DPD--Turns red and uses a comparator, FAS-DPD--titration test that goes from pink to colorless, you count drops) and how often and also how often you are adding chlorine. In the presence of algae free chlorine is cosumed very quickly, which is why the chlorine needs to be added at least 2 or 3 times a day to maintain the level. Also, you have NO cya in your water so your chlorine will burn off in a matter of minutes in the sun! That means your pool has more time without any chlorine than with unless you are adding it every hour througout the day. This will allow the algae to continue to grow.
    Finally, don't try and test pH when your chlorine levels are above about 10 ppm because you will get a false high pH reading. Wait until the level drops and then test. I suspect your pH is really much lower than 8.0-8.2!
    Edit: also, did you ever change your filter sand after the conversion from baqua last year? If not this might be adding to the problem. Any baquagoo that is trapped in the sand will also consume chlorine and lower the amount available for killing the algae.
    jmjbj_h Guest
    Thanks for the reply, I use a Taylor FAS-DPD Test and do titrate. I used to use Baquagunk but changed my filter and liner last year and went BBB. I test before I pour always. I have been doing it 2 to 3 times a day. My clorine has been consistently that high when I test. About half gets consumed during the daylight hours, maybe more. What am I not doing right??
    Indiana.
    Quote Originally Posted by jmjbj_h View Post
    If you have algae AND no CYA, you would have to add chlorine almost hourly to maintain any kind of FC level. Maybe you've killed it. The water turns blue-gray when the algae dies, and maybe liner color or pollen MIGHT be throwing the color off.
    The sun is probably eating it during the day, but if it holds overnight, I can't imagine you have any algae left. Have you considered that it could be a copper issue?
    jmjbj_h Guest
    I thought of the copper, but I can't think of where it would come from. I put in poly at closing and that is the only think I have done different. How would I know if that is the issue?
    My best guess is that your chlorine got used up over the winter and the PolyQuat 60 lasted for a while and then also got used up. When that happened, the algae could take off. Also, bacteria consumed the CYA producing ammonia which made for nice algae food (algae need nitrogen -- typically from nitrates, but ammonia will do nicely).
    JohnT is right that without any measurable CYA any chlorine you add will get cut in half in about a half hour in direct noontime sun. I suggest you add Dichlor granules/powder since that will add both chlorine and CYA. You don't want to add too much. It takes 3 pounds of Dichlor per 10,000 gallons to raise the FC by 20 ppm and the CYA by 18 ppm. So I would add enough Dichlor to cumulatively add about 20 ppm of FC since the 18 ppm CYA should be enough to keep the chlorine from burning away too quickly (you can always add more later). Look at this post for some brands of Dichlor if you don't know of any.
    Then, hit the algae hard with bleach or chlorinating liquid, maintaining the FC level at a minimum of 10 ppm FC though you could target 15 ppm to make things go faster.
    JohnT may be very right that you have copper that has precipitated at the high pH which would make any gray/white cloud (of dead algae) look green. However, the dead algae should filter out and breakdown from the chlorine if you run the filter 24/7, expose the pool to sunlight, and keep the chlorine level high (you might clean the filter, especially if you see a rise in pressure). If your pool doesn't start to clear in 48 hours, then we can look at other things. By the way, what is your CH level? Maybe the TA, high pH and a high CH has your pool cloudy from calcium carbonate.
    Richard
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 12:51 PM
  3. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
  4. green pool: like black/green pool
    By bazman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2010, 11:25 AM
  5. green green pool
    By mr greenpool in forum Dealing with Algae & Slime
    Last Post: 07-09-2006, 02:04 PM
